Kod: Tümünü seç
on *:LOAD: {
echo -a _____________________________________________________
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Loading Add-On...
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Add-on: 09 Nick/Address Tracking 15 Add-On
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 You are running mIRC $version on $os $+ .
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Coder: 15SaNCaK 0,1 E-Mail: 15SaNCaK@SaNCaK.gen.tr
echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Copyright © 200915 http://www.sancak.gen.tr
echo -a ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
hmake addtrack 10000
menu channel,menubar,nicklist {
Nick Tracking
.$iif($group(#Addtrack) == on,$style(1)) Show used nicks on join (*@host): {
var %status = $iif($group(#Addtrack) == on,Disable,Enable)
$+(.,%status) #Addtrack
echo 7 -at * Users previous nicks will $iif(%status == Disable,no longer,now) be shown when they join.
.$iif($1,Check nicks for $1):CheckNicks $1
.Check nicks for an address: {
CheckNicks $+(*!,$$?="Enter the hostmask you want to check in the format NICK!IDENT@HOST*")
on *:start: {
if ($isfile(addtrack.hsh)) hload addtrack addtrack.hsh
on *:exit: {
if ($hget(addtrack)) hsave -o addtrack addtrack.hsh
#Addtrack off
on *:join:#: {
if ($wildsite iswm $address($me,5)) return
var %mask = $mask($fulladdress,2)
if ($hget(addtrack,%mask)) {
var %usednicks = $ifmatch
if (%usednicks != $nick) && ($group(#Addtrack) == on) echo 14 -t $chan 14 [Nick Tracking] $nick has also used the nick[s]: 7 $+ $remtok(%usednicks,$nick,1,44)
if (!$istok(%usednicks,$nick,44)) hadd -m addtrack %mask $addtok(%usednicks,$nick,44)
if ($numtok(%usednicks,44) > 10) hadd -m addtrack %mask $deltok(%usednicks,1,44)
else {
hadd -m addtrack %mask $nick
on *:nick: {
if (!$istok(%usednicks,$newnick,44)) hadd -m addtrack %mask $addtok(%usednicks,$newnick,44)
else {
hadd -m addtrack %mask $newnick
#Addtrack end
alias CheckNicks {
if (*!*@* iswm $1) {
var %mask = $mask($1,2)
if (!$hget(addtrack,%mask)) echo 4 -ta [Nick Tracking (*@host)] No entry found for $1
else echo 10 -ta Address $1 has used the nick[s]: 7 $+ $hget(addtrack,$1)
elseif (!$hget(addtrack,$address($1,2))) echo 4 -ta [Nick Tracking (*@host)] No entry found for $1
elseif ($hget(addtrack,$address($1,2)) != $1) {
echo 10 -ta [Nick Tracking (*@host)] $1 has also used the nick[s]: 7 $+ $remtok(%usednicks,$1,1,43)
else echo 10 -ta [Nick Tracking (*@host)] $1 has not been seen using any other nicks.
