Küfür Koruma Eklentisi
Kullanıcı avatarı
SaNCaK
Admin
Admin
Kayıt: 21 Eyl 2010, 17:22
Mesaj gönderen SaNCaK »
Kod: Tümünü seç
on *:load: {
  .echo -aq $input(Yapımcı: SaNCaK $+ $crlf $+ $crlf $+ Addon: Küfür Koruma $chr(40) $+ v5.4 $+ $chr(41) $+ $crlf $+ $crlf $+ Yapım: 17/10/2014 $+ $crlf $+ $crlf $+ Iletişim: sancak@outlook.com.tr $+ $crlf $+ $crlf $+ Kodu Kullandığınız için Teşekkür ederim,igo,Addon: Küfür Koruma $chr(40) $+ v5.4 $+ $chr(41))
  echo -a _____________________________________________________________________________________
  echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Add-On yükleniyor...
  echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Çalışan mIRC15 $version 0Sistem15 Windows $+ $os
  echo -a 4,1[15,1 SaNCaK 4,1] 0,1 Coder: 15SaNCaK 0,1 E-Mail: 15sancak@outlook.com.tr
  echo -a 4,1[00,01 SaNCaK 4,1] 15,1 Copyright 12©15 1999-2017
  echo -a ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
on *:unload: {
  .echo -aq $input(Author: SaNCaK $+ $crlf $+ $crlf $+ Addon: Küfür Koruma $chr(40) $+ v5.4 $+ $chr(41) $+ $crlf $+ $crlf $+ Released at: 17/10/2016 $+ $crlf $+ $crlf $+ Contact: sancak@outlook.com.tr $+ $crlf $+ $crlf $+ Unloading...,igo,Addon: Küfür Koruma $chr(40) $+ v5.4 $+ $chr(41))
; Aliases
alias -l cx.swear {
  if ($isid) { return $readini $scriptdircx-swear.ini settings $1 }
  else { .writeini $scriptdircx-swear.ini settings $1 $2- }
alias -l cx.hash {
  if ($hget(cx.list,0) == $lines($scriptdircx-swear.txt)) return
  if ($hget(cx.list)) hfree cx.list
  hmake cx.list 1000
  var %i = 0
  while (%i < $lines($scriptdircx-swear.txt)) {
    inc %i
    var %cx.input = [ $read -l [ $+ [ %i ] ] $scriptdircx-swear.txt ]
    hadd cx.list %i %cx.input
alias -l cx.swear.chk {
  var %i = 0
  while (%i < $hget(cx.list,0).item) {
    inc %i
    if ($hget(cx.list,%i) iswm $1-) { return $true }
  return $false
; Popups
MENU menubar,channel {
  Küfür Koruma:.dialog -m cx.swear cx.swear
; Dialogs
dialog cx.swear {
  title ">> Küfür Koruması"
  size -1 -1 124 84
  option dbu notheme
  button "done", 1, 50 74 24 9, flat cancel
  box "Küfür Koruma Ayarları", 2, 0 28 124 44
  button "sil", 3, 100 55 16 10, flat
  combo 4, 4 55 92 50, sort drop
  button "ekle", 5, 100 40 16 10, flat
  edit "", 6, 4 40 92 11, autohs
  box "Durum", 7, 0 0 124 24
  radio "Kapalı", 8, 87 10 36 8, flat
  radio "Açık", 9, 8 10 32 8, flat
on *:DIALOG:cx.swear:*:*: {
  if (($devent == INIT) && ($did == 0)) {
    if ($cx.swear(toggle) == enable) {
      did -c $dname 9 | did -u $dname 8 | did -e $dname 3,4,5,6
      var %i = 0
        inc %i
        .did -a $dname 4 [ $read -l [ $+ [ %i ] ] $scriptdircx-swear.txt ]
    else { did -c $dname 8 | did -u $dname 9 | did -b $dname 3,4,5,6 }
  if ($devent == SCLICK) {
    if ($did == 3) { if ($did($dname,4).sel) { .write -dw [ $+ [ $did($dname,4).text ] ] $scriptdircx-swear.txt | did -d $dname 4 $did($dname,4).sel } }
    if ($did == 5) { if ($did($dname,6).text) { did -a $dname 4 $ifmatch | .write $scriptdircx-swear.txt $ifmatch } }
    if ($did == 8) { cx.swear toggle disable | did -c $dname 8 | did -u $dname 9 | did -b $dname 3,4,5,6 }
    if ($did == 9) { cx.swear toggle enable | did -c $dname 9 | did -u $dname 8 | did -e $dname 3,4,5,6 }
; Remote
on *:TEXT:*:#: {
  if ((($me isop $chan) && ($nick !isop $chan) && ($cx.swear(toggle) == enable))) {
    cx.hash
    if ($cx.swear.chk($strip($1-)) == $true) {
      .raw MODE # +b $wildsite
      .kick # $nick >>> Swear protection.
